help casio AT-5
hello :)
i'd like to know if you can give me oriental rythms for this keyboard like "DABKA" for example cause i didn't found it
and thanks :)
Hi There,
In the absence of anyone giving you any they've already created - the complete list of rhythms can be found here:
http://support.casio.com/pdf/008/Web_07H3APPEND-WL-1B.pdf
As you can see there are quite a few Arabic rhythms in there. Although there is nothing labelled "Dabke" specifically, check this out.
How to select them - this simple video shows you. Watch from 0:50:
Cheers!
thank you but u didn't understand what i mean :p
i asked if this rythm is available "created by someone" and i add it by USB or SD Card :)
aha! i have some rhythms of other keyboards with this extension ( .prs) can i convert them to work on casio?
