Looking for a new stand
I'm looking for a two tier stand but also that has a mic stand built in on the left and right side. One for a microphone and the other one where I can mount my theremin. Suggestions are welcome please.
EL
I essentially started out with an Onstage Two Tier Z stand and added a few parts and built my own similar rig.
With the right compatible attachments it's pretty easily doable.
Ask here if you can't find the part numbers and I'll try to dig them up.
They're all Onstage parts and they're very reasonably priced.
Perfect! You already have the most expensive part. You should be able to pick up the rest of the parts for around $75 or so.
I used all Onstage parts to ensure compatibility. Except for the Music Rest which was a generic clamp on part.
New To V-Stage
