Prs s970 keyboard stand
Stoke on Trent
Hi well l phoned Yamaha yesterday day l wanted to make sure before l went out and bought one they told it will fit but l would not be able to use the screws to secure it but it will sit on the top, so l will have a look at one and see if l can make a weld a bracket on l will let you know how l get on
That's weird-- I'd have thought they wouldn't have listed it as compatible unless it could be attached by screws as intended, otherwise it seems like they could probably also list that stand as being compatible with the PSR-E models-- which they don't do.
