Roland AX-7 to Roland E-70 HELP!
I have just got a Roland AX-7 keytar, it does not make sound on its own, it is connected to my Roland E-70 Synthesizer via MIDI.
So far I seem to have settings alright on both keyboards, if I use the functions on the AX-7 it works on the E-70, apart from ONE (very important) thing:
If I press the keys on my E-70, sound is made (and can be adjusted by the AX-7).
If I press the keys on my AX-7, nothing happens.
So basically I have an expensive keytar that doesn't make sound with its keys (although the pitch bend, tone etc work with the E-70)
Desperately needing help here!!!!!
