Round Robin
Hi All
I bought Roland E-A7 Arranger workstation and wondering if this thing is possible.
I'm trying to use multiple samples assigned to the same Key (Round Robin) so for example every time I hit hit D2 for snare sound, it will play different sample so it will be more real. This Round Robin is applied in the new Yamaha PSR A5000 and called Revo.
Anyhow, in other keyboards, it is only possible to put other samples on different velocity layers which is not practical as I lose the touch sensitivity for this layer.
for example if I use the first snare sample to play from layer 1 to 120, the second sample to play from layer 121-127.
Is their a function to control the Velocity Response curve???
josetabito
