Set up midi out with Roland A-80
I am trying to play music with FL Studio using my Roland A-80. I have a simple midi in/out to usb cable. I have set the correct settings on FL Studio 10 to receive midi input but Im getting no input. What should I do to output MIDI from the A-80? I have the MIDI cables connected to MIDI IN 1 and MIDI OUT 1. What should I check for? Thank you a lot in advance
North Wales
I have a Roland A90, not sure if it's the same. On the A90 there are four MIDI outs, basically hook up the interface to MIDI out A, and on the keyboard itself there are four buttons for each output, press the button for MIDI out A until it goes orange, that's it. It's now transmitting over that port. Hope that helps.
New To V-Stage
