I recently pulled my old yamaha M06, it still works perfectly but, i can't seem to get it connected to to win 10. I tried downloading the drivers and tried several different configurations.... can anyone point me in the right direction.
To get your MO6 connected, keep these crucial steps in mind:
- Download the right version: Most modern Windows 10 setups require the 64-bit version. You can download the official installer directly from the Yamaha MO6 Support Page.
- The "Plug-In First" Rule: Yamaha drivers are notorious for failing to install if they can't detect the hardware. You must connect the MO6 to your computer via USB and turn the keyboard ON before running the driver installation wizard.
- Set the keyboard's MIDI mode: On your MO6, make sure the system settings are routing MIDI through the USB port rather than the standard 5-pin MIDI jacks. (Press UTILITY > F5 MIDI > SF4 OTHER > Set MIDI IN/OUT to USB).
