Water in keyboard
Hello, 2 hours ago, I spilled water into my keyboard, at first, I started to clean up the mess on the table...
I know I am stupid and I should have plugged the keyboard off, but I did after like 8 mins.
Before I plugged it off, the keyboard typed random things and when for example I clicked backspace, the keyboard typed like the letter "P". In the morning, I am going to blowdry the the keyboard on the lowest settings.
Do you think the keyboard is going to work? Or i plugged it off too late.
Thanks for any help.
I'm not sure, but here's the good news. You can replace the sort of keyboard you're talking about starting at about $50.
If it were the sort of keyboard that we like to talk about on this forum, it would be significantly more expensive.
Which is weird really. It seems your keyboard has a letter "P", where ours only go up to the the letter "G#". I think you've come out of it better than us!
Good luck.
Good luck.
My keyboard is a Logitech G810, any ideas how much could that cost? Thanks for your reply.
Google tells me that you can get a Logitech G810 for AUD149. Ouch! Those gaming keyboards are really pricey...
Alternatively if you want something really nice, you can get a Korg Kronos 88 for AUD4999. It's a bit more money but I don't think the Logitech has Smooth Sound Transition.
Oh shit i thought this was a different type of keyboards forum. Fml
I just did what I was planing to do, and it looks like it worked!! So glad it did. Thanks for you help guys
New To V-Stage
