Best, smoothest, full range Expression Pedal to buy?
have tried several, including the much celebrated Ernie Ball, and have yet to find one where the volume is smooth from silent to wide open, and holds up to the rigors of performance!
Thanking you in advance!
Sounds that the response curve needs to be set to suit your requirements.
Probably the default is a linear slope.
Check with the manual of your Keyboard
If you can find one (NLA new) a Roland EV-7. Long sweep and smooth linear slope. 10K pot. Also, Yamaha FC7. Polarity (tip/ring) backward from Roland, in other words on the Roland the wiper is measured by the tip and on the Yamaha the wiper is measured by the ring ( I may have this backwards). What does this mean; many have reported erratic linear slope, depending on what the requirements of the keyboard are vs. what the pedal provides. Easy fix though. Just purchase the below, hooking up the red to the black and this will switch the tip/ring and most of the time produce the linear slope needed.
The Yamaha FC7 has the largest sweep of the two, but the EV7 does have an acceptable long sweep to play hammond organ. I own both pedals, both are acceptable. Stay away from the Roland EV-5. The pedal doesn't have a long enough sweep to actually produce any real expression, especially when playing organ.
Bradders
