A sustain pedal for a keyboard, preferable one equipped with something to stop it from slipping. What do you recommend and how can I get it?
My keyboard is a Yamaha DGX-660. And thanks very much for the reply. There are sustain pedals somewhere which have something flat and sort of floppy attached underneath it, which you flip out to the front and the idea is that you keep your heal on it while using the pedal so it stops the pedal from moving. I have only ever seen one of these in a college I attend.You didn't mention what make and model keyboard, but there are universal pedals that work with nearly all models.
Personally I use a bunch of M-Audio SP2 pedals.
They're universal and they are built like a brick outhouse.
They have rubber feet and they are quite heavy so they don't slide around.
And they are decently priced so they won't break the bank.
Amazon.com: M-Audio SP-2 | Universal Sustain Pedal with Piano Style Action for Electronic Keyboards: Musical Instruments
Amazon.com: M-Audio SP-2 | Universal Sustain Pedal with Piano Style Action for Electronic Keyboards: Musical Instrumentswww.amazon.com
Gary![]()
I know someone who tapes their sustain pedal to the floorA sustain pedal for a keyboard, preferable one equipped with something to stop it from slipping. What do you recommend and how can I get it?
If you take a sustain pedal as circled in the picture above and turned it 90 degrees it won't slip. Don't ask me why, but it works.
This is true! - I can vouch for it when my practice pedal at home goes rogue on me.If you take a sustain pedal as circled in the picture above and turned it 90 degrees it won't slip. Don't ask me why, but it works.
As it happens, I had already found an M-Audio SP2 pedal on Amazon and ordered it. It has arrived now and it's great. It's better than just the simple square-shaped one (this one broke) that came with the keyboard. Its 6 foot cable suits one of my needs for it too; just now I need the cable to be that long. Now I think I'll look for another one to buy in case the one I've got now breaks ever. To suddenly not have a sustain pedal is awful. I would like one with that thing you keep your heal on to stop it from moving while using it.You didn't mention what make and model keyboard, but there are universal pedals that work with nearly all models.
Gary![]()
I use a universal and wrap a small bungee cord around that and the foot of the stand to keep it from running away from me.A sustain pedal for a keyboard, preferable one equipped with something to stop it from slipping. What do you recommend and how can I get it?
I have 2 easy options.A sustain pedal for a keyboard, preferable one equipped with something to stop it from slipping. What do you recommend and how can I get it?
The Roland DP-10 sustain pedal is equipped with the rubber heel extension you are describing. I am not 100% positive it will work with the Yamaha DGX-660 but it does have a polarity switch on the side so chances are one of the settings will work to sustain.
I tried this at rehearsal last night. I think it might work for me, but my foot had trouble learning a new position after so many decades! I'll keep trying though. Thanks for the tip.If you take a sustain pedal as circled in the picture above and turned it 90 degrees it won't slip. Don't ask me why, but it works.
My band moves around quite a bit, so this sounds like a light, easy option. I'm going to try it today Thanks for posting.I use a universal and wrap a small bungee cord around that and the foot of the stand to keep it from running away from me.
Thanks for this tip. Definitely one that I'll try.I have 2 easy options.
1. Rectangle carpet w rubber backing. Place pedal (s) on that.
2. Usually there are base plate screws on bottom of pedal. I removed 2screws at front end & inserted piece of flexible rubber width of pedal & 8-10” long that my heel rests on. Never an issue over 5 yrs of using 2 keyboards.
Don’t have to worry about taping,residue glue, & added weight.
