Connect 2 Keyboards to 1 PC
Hey guys. Im quite new to the MIDI Keyboard scene and i have one question on wich i havent found a solid anwer yet.
I have an Aturia Keystep wich i connect via USB to my PC. is it possible to connect my Keystep via an MIDI cable to another Midi Keyboard to use both as Masterkeyboards. So that the other keyboard also sends midi signals instead of playing sounds from the onboard speakers/sound library
If all you have on the second keyboard is MIDI ports then the simplest solution is to use a Class Compliant USB MIDI Interface and plug both into the computer using a couple of USB connections. Then you can control both using your DAW software and/or MIDI Routing Software like MIDI Yoke http://www.midiox.com/ if you wish to layer the two.
