I can't help you with your question unfortunately, but just wanted to say welcome to the forum!
Hej Obi 1 macaroni,
I think there is a possibility for that what you want.
First you have to download a special manual called: Computer-related operations;
you'll find it here:
http://download.yamaha.com/search/p...maha.com&category_id=16084&product_id=1789582
Read this very attentively; especially page 11. Perhaps you need the Yamaha software:
Musicsoft Downloader. You find how to download this in the manual too.
Good luck!
first thanks a lot for the fast reply and thanks to Becky for the warm welcome,
thanks goldi5210 i read the pdf, maybe u can help me understand,
there's a pdf called 'Computer-related Operations' this is the 1 i read (and also the manual)
it seems that the 'Computer-related Operations' one is general for all psr's and not specifically the e243 because it talks about transfering a style file to the keyboard but then in the bottom if u'll look u'll c it lists the models that can bring in external style and there is no V on e243 the only one with lowest price that is marked down there with a V as possible to bring in external styles is the e343, and then when i read the e343 manual its the only one (this one and above it) that says in the manual u can import an external style file, while the e333 and lower don't have that option in their manual (even though they all have the 'Computer-related Operations' which says how to transfer a style file but its the same pdf for all the psr's so i guess its a general pdf and not specific for each model, unlike each model's manual), so correct me if i'm wrong, i guess the lowest price with ability to import external style is e343?... thanks again!
actually I rechecked and e313 is the lowest one with possibility to import external style files... i think, correct me if i'm wrong, thanks in advance.
