Oogie Wa Wa
Nate, bass and keys for The Feds Band
I got an expression pedal. I'm pretty sure it's the right kind, although I may need to swap polarity.
I want to control all the Patch volumes except for the bass 'guitar' Patch with it, in my Performances/Favorites so at times I can fade them out or bring them down a little.
I see how to assign the Control Pedal to a CC (or MIDI function) in the global system menu. They are CC7 for Volume and CC11 for Expression.
I see in the Performance parameters that I can selectively turn the receipt of the signal for each Patch present; Checking or unchecking VO or EX. Both are checked.
So I believe that I should select one of the pedal functions, and leave the the checks set for both on my Performances
So, being a total MIDIot, which one should I use? Is there a difference? I understand the both, playing electric organ and bass guitar. To me they are essentially the same thing. Will either one work? Is there some limitation (or perhaps tradition?) that I need to know.
Thank you all kindly, as always.
