Good Keyboard For Recording?
Hi friends,
I'm looking for a good quality keyboard for recording with:
Excellent quality sounds with fairly large data bank.​
Ability to load more sounds or samples into the keyboard in order to get other sounds that I may also want to use.​
Full size keys. Action style is not real important.​
I don't need a workstation or an arranger. I also don't need built in speakers since it will be used primarily for recording.
My budget is $1500 or less.
Thanks for your help.
Steve
Kurzweil PC3LE6 or PC3LE7 or PC3LE8.
Personally if I were shopping around right now I'd be buying myself the PC3LE8.
Amazing MIDI Features and amazingly powerful and configurable sound synthesis engine. Allows loadable sounds.
If you're willing to jump $500 to $800 in your budget the PC3K family allows sampling as well.
Anyway that's what's on my workstation wishlist right now.
New To V-Stage
