greetings and salutations
Jacksonville, FL
HI All, I've been at this for quite a few years starting on piano, later organ and finally keyboard. -with a few stops along the way to play guitar or later bass. Now I play keyboards and lead vocals for a swing band called "The Manhattans". I do an occasional solo or duo gig as well. My preferred boards are a Yamaha P80 piano on bottom with either a Fantom 76 or a Juno D on top. I also sometimes run an AX1 into a JV1010. With my main band gig I use a pair of Behringer B215's to run stereo. Otherwise I use one of several Roland keyboard amps or sometimes a SOundTech ALR2. Solo I sometimes run ShowPlay4 into a JV1010 module for sequences but I'm not big on sequences in general.
Gerry
Similar Threads
Greetings. New member 8
greetings 5
Greetings! 9
Belated Greetings 6
AlexonFergus Wishes You Well & Extends Greetings! 5
Greetings From New Zealand 7
Greetings/PSR E433 7
Greetings and Salutations! 2
New To V-Stage
