Korg x50 Keys Switch up Randomly
Greetings ! I have a question for Korg X50 owners. I have owned mines for over 3 years now. It recently happened to me while playing a gig! The Keys changed all on their own! I was playing Gminor chords and it was playing in completely different key! I had to turn on and off the keyboard to basically reset it.
Has this happened to anyone before and does anyone know what it is or is it time to get a new keyboard? Thanks!
Were you using the pitch control wheel at the time?
To test out if the pitch wheel is the culprit try disabling it in the keyboard menus and see if the problem returns or not.
If so, the pitch controller may be shot and it's generally a pretty easy fix to replace it.
Thanks for the Response! I was using sustain pedal and also a delay pedal. No pitch control. How do I disable the pitch wheel. I would like to disable it. I dont have owners manual for I bought the keyboard off somebeody else. Thanks!
Bradders
