Music stand for yamaha keyboard
Hello! I have acquired a second hand yamaha YPT-220 (PSR-E213) keyboard and have enjoyed learning over the last month. I'm now ready to start reading music but it doesn't have a music note stand - does anyone know of one that will fit? I can't find one online that says it does.
T.I.A Georgina
California
You are probably thinking about a tabletop music stand. I've owned a couple and they are not satisfactory. You will be better off with a stand similar to the one biggles posted. The price range is cheep to expensive. If weight is an issue you will be looking at ones with a lot of holes in the music holder part. Good luck and happy New Year.
Thanks for your response.
I was hoping somebody would know of a note holder that is attachable to the keyboard itself. Do you think it's not possible which is why both yourself and Biggles suggested an actual stand?
Thanks again and Happy New Year to you too :)
EBay search:-
Replacement music rest for Yamaha keyboard.
You will get a few responses and for a few bucks you can take a punt on one.
If needed a hacksaw and file can shape the support to suit your keyboard.
