Pads
Hertfordshire UK
I would like to use an arpeggio sound, on a pad, to use with a style. Could somebody advise please how you do this. I did do this on the tyros 4 but not sure how it is done on my Korg. Thanks
Save the Style that you intend to use as a Song.
Basically then use Step Recorder to create your arp pattern.
Load the arp pattern into the Song, rename it to suit then save.
Now each time you load the song your arp pattern will be on the Pad where you saved it to.
On a PA700 the manual goes into great detail from page c240.
Or
To see how it is done log into the live Q&A webinar at 17:00 tonight or watch it when you can offline. I will be watching it and will pose the question so hopefully Luke will go through how it is done properly.
Hertfordshire UK
Hi Col, thanks for the reply. I was on the webinar early but question was missed. I have used an arpeggio as an addition to a style and sometimes it is nice on it's own. The following was all pa 4x's, was surprised other boards did not show. dave
