PF-80 How to Remove Key?
I was given an old Yamaha PF80. The lowest black key sticks. How do I remove the key?
Most of those display an arrow on each key indicating where to press down to release the key. The PF-80 has no arrows on the keys so I assume it's a different method.
If you can't lay your hands on a service manual then you'll have to figure out the minor differences by yourself.
