Psr-433 fill a->a or b->b
Hi folks,
I just received my second hand Yamaha Psr-433 keyboard en it sounds great!
I already read the manual.
But still I have a question about the fill-in.
I only can find the auto fill button that goes from A -> B and B -> A
But what it you just want a normal fill in? So if it is playing main A after the fill it is still at MAIN A and when playing MAIN B then it should be playing MAIN B after the “normal” fill. How can i do this?
Many thanks for all the help
kind regards,
Robert
The panel style controls don't support that, so if you want to do a 1-bar fill and resume with the same variation you'll need to press the button once to start the fill, then again while the fill is playing (A->B then B->A, or B->A then A->B).
