Rhythm of a Song
Hi All...
Its easy to find notation of any song on internet, but nowhere it is mentioned that which Rhythm should be played with it.
Can any one help about it?
Thanx
Ghufran
Ghufran,
See the various databases available for download from this link:
http://psrtutorial.com/sty/OF/musicfinder.html
and the related database viewer/editor program available at this link:
http://psrtutorial.com/MB/musicfinderview.html
Yes ! These files are Yamaha oriented, but if you are going to play "Goodnight, Irene", the recommended rhythm style and tempo would be the same, whether you play it on a Yamaha or a Casio, so you should be able to get at least some use out of them. The only difference is, if you are using a Yamaha keyboard, the database can be loaded into and viewed directly from the keyboard itself. If you do find these useful, under the viewer/editor program's "File" dropdown menu is an option to print the database. Just be aware that most of these databases have in excess of a thousand entries, so the printed output could get a bit lengthy. For my "non-Yamaha" arrangers, I keep a copy of the databases and the viewer/editor program on a small netbook next to the keyboard, and for my "all time, most popular favorites", I just save them under the keyboard's "Registration" feature.
Good luck !
