Roland VR09B Registration Bank Switching via External MIDI?
London
Hello,
Is there any way to switch between Registration Banks on the VR09B via external MIDI?
I'm running a dual keyboard setup (Yamaha CP88 & Roland VR09B) with a Quad Cortex. The QC can send PCs and CCs to both keyboards; the Yamaha is responding to my patch changes perfectly, but the Roland doesn't. Meaning I have to hit the patch change on the Quad and then change the Roland seperately.
At best, any PCs I've tried sending result in the VR09B changing to an individual sound (not the saved presets I have registered on my registration banks).
Is there someway to do this? I hope so, as I've already had disappointment with the VR09B not sending CCs from it's drawbars, instead doing sysEx.
Are these features that don't come at this age/price bracket of gear?
Hungary
"It's impossible to select VR registrations from external, e.g. from setlist apps, is really a big development fail. The point is: VR has the option to step forward registrations by using the PK-IN MIDI socket, so it's hard to believe that the 'internal concept' would not have allowed to implement 'free selection by MIDI' - or at least fix the issue by firmware updates after all those customer complaints. There are several strategies:
1. For each gig, reorder the registrations (using VR menu or ctrlr upg editor) so that you just have to step forward ('next' button, foot pedal, PK-IN MIDI).
2. In the setlist app, note the VR reg number for each song, then spin-spin-spin the dial-dial-dial.
3. Use VR as 'setlist master': while VR registrations cannot be selected by MIDI program change, they can send Program Changes to other keyboards or setlist apps: you do not change VR registrations by setlist maker but change setlist maker songs by VR registrations - of course that implies that you create one registration for each song even if registrations are redundant (e.g. 'default piano' for a couple of songs)."
(Frank Vcombo-Editor, 7 May 2023)
Betzi
