Stand for RD-88
My Roland rd-88 is about 5" in height from base to top of white keys. The piano stand I am using results in the top of the keys being 31" or more from the floor, which means my piano bench is maxed out. The whole thing feels awkward.
Has anyone found a great piano stand for the RD-88? I would like a stand that is easy to setup at gigs, but which can be set at about 23" from the ground - putting the keys at between 28-29" from the ground.
Any help would be appreciated.
welcome
Checkout a K&M 18820 stand height 600 (23.6”) - 1050mm (41.3”).
This is the foldable version, I use a 18810 which has the same height range but is non-foldable.
Mine looks good and is rock solid, downside is they are quite expensive.
josetabito
