starting out
tasmania,australia
Gday
Getting a Yamaha PSR E233.,arrives soon.Dont need to become a great keyboardist,singalong would be fine...irish folk,60's hits.Couple of questions.
Do i use the the yamaha Y.E.S. learning programme,or buy a book?
Is it best to learn RH melody first then LH chords then put together or vica versa ?
re mick
Perth, Scotland
Welcome to the forum. May not be anyone on here with that keyboard.
Have you a bit of chord knowledge already from playing guitar maybe?
tasmania,australia
hello goz
Just talking generally...do you master one hand doing melodys and then learn chords with the other and then together ?
The Y.E.S. learning program seems to have been on yamaha keyboards for awhile.Just wondering if anyone has used it to learn or thought it was crap and got a book to learn insteasd
re mick
Perth, Scotland
A bit of guitar. If you know a few chords on guitar and can accompany yourself while you're singing, quickest way to get going is to get a keyboard player to show you a way to play those chords on the keyboard.
Just play the root note of the chord (the one that gives the chord its name) in the left hand - and the notes of the chord in the right. Tap your foot for a bit of rhythm - you won't have the pulse of a strum the way you do on guitar.
If you are confident enough to sing and accompany yourself - that may be all you ever need to do - one bass note in the left, chord with the right.
To learn melody in the right hand and chords in the left:
Once you can chord your way through a song while singing or humming the melody, try picking out simple tunes that you can already sing with your right hand. One phrase at a time. Once you can play it the whole way through, add the bass note in the left.
That's for playing the stuff you're talking about.
Bradders
