Yamaha Psr s650 or psr s700 which one is a better choice?
Thinking about the next keyboard I have a psr e433
At the moment and the budget will let me buy either
650 or 700.which one is a better choice?
I know that 700 let You record a songs as a wav
Format and has 128 bit polyphony.650 has
64 bit polyphony,but its a newer model...
Any suggestions?
I don't give advice as it is a personal thing for taste and budget of course.
WAV or MP3 you can record from almost any keyboard trough line out or even headphone out to a computer and using for example free to download Audacity as recording program. Yes onboard recording is handy and nice but how often are you planning to do that.....
Polyphony: depending how good you can play. Using ten fingers and playing LARGE sounds like full orchestra or BIG bigband the higher the polyphony the better. But I still have my good old PSR 2000 with 64 polyphony and I never had a problem with clipping and I play big ones in awhile.
My 2 cents.
Best of luck
DickR
Bradders
