- Joined
- May 10, 2018
- Messages
- 4
- Reaction score
- 2
Odd phenomenon, and my main dilemma.
when I used previous sustain pedals on my midi keyboards in my old studio setup, they'd extend a note's "tail" - which we all know to be the main function of the sustain pedal, (far right).
The problem I have, is that when I press the sustain pedal, no matter which software synth (AU), the pedal instead simply holds the notes down, - the equivalent of if I were to hold down the notes with my hands. When I lift my foot and release the pedal, the note hold stops. in most cases, the note would eventually "end" after it's extended tail trailed off, etc etc. This is not what the Yamaha 3P7A pedals appear to be doing. They appear to be HOLDING the notes indefinitely.
I don't want a note "hold" to be the function of the sustain pedal. I just want the notes to have a longer tail and act more like a traditional piano would when pressing the pedal. Almost all my soft synth plugins would read the old sustain foot switch I used to have, and do just that, and the note "hold" was never an issue.
The sustain pedal of my Yamaha 3P7A appears to have a more advanced "3 way" function type switch. One midi note when pedal is off (0), one for when pressed all the way (127), and a 3rd one (46 i think?) for when the pedal is at middle or somewhere along the movement path. I cant remember specifics. I just know it's a 3 way function, rather than just on / off, and probably has something to do with the the note muffling / dampening feature (lightly releasing or pressing the pedal will cause the piano to sound more like a real sustain pedal) , - but that feature is useless and a burden in my DAW and I want it disabled, and have tried, but it remains a problem. - and that really screws with the synths, because they all seem to think that the "note hold" is the correct thing to do when the pedal gets pressed. - so frustrating.
Anyone know how to resolve? Is it something I have to dissable in the DGX settings (I tried em all I thought) or something I have to switch off or disable in Logic?
