Smartmedia cards for Triton Le?
Discussion in 'General Keyboard Discussion' started by Beckster, Mar 12, 2009.
  1. Beckster New Member
    Feb 22, 2009
    Message Count:
    11
    Hello all :)
    Have a Triton Le 61 cheers John :)
    and have expanded the wee beast with the Sampling upgrade.
    Can anyone provide information or linkage to anyone who sells the correct type of Smartmedia card for the Le? I realise it's old technology just hoping they can still be grabbed from somewhere.
    I found these:
    http://www.amazon.co.uk/SmartMedia-Cards-Memory-Readers/b?ie=UTF8&node=564502
    But am not sure which (if any) are correct. Thanks for any and all help guys :)
      • Advertising
  2. bsr2002 New Member
    Oct 16, 2008
    Message Count:
    71
    TEXAS
    They will work :cool:
  3. Beckster New Member
    Feb 22, 2009
    Message Count:
    11
    cheers mate :)
    Downer you can't save anything internally but new to this side of things hence why I havn't got a clue.
    16mb of ram came with the sampler. So for example if I create a sample that lasts the maximum sampling time I am using the full 16 mb's correct?
    Im grabbing a couple of smartmedia (128mb each) to start off with. Would I be better getting something that connects to the scsi to save my stuff that way and if so can anyone help me with what to get? What particular device etc?
    I'm also interested in using my computer for storage. Is there anyway of connecting the Triton to my computer (SCSI - USB) for example?
    Im ok with the midi dump stuff and have managed to sort that out no problems.
    Thanks again for any and all help.
  4. kanthos New Member
    Nov 5, 2008
    Message Count:
    433
    Newmarket, Ontario, Canada
    Yes. Keep in mind that 16 MB takes a *long* time to load (my Korg TR, a step up from the LE, would be sitting around for 5 minutes or more, depending on the format and number of individual samples, to load a 10 MB program).
    You'd probably have a hard time finding any compatible device. I'd just stick with the cards. They'll also work for backing up your programs and combis as well.
    I'd get a card reader that handles SmartMedia cards, and use that. SCSI is archaic; don't use it unless you have no other choice.
      • Advertising
  5. bsr2002 New Member
    Oct 16, 2008
    Message Count:
    71
    TEXAS
    2nd the card reader :)
  6. Mourndark New Member
    Jul 6, 2008
    Message Count:
    294
    Bath or Durham, England
    No. SCSI is a very old standard and the way it handles multiple devices means that you need special hardware to use it. Stick with SM cards, even if they're hard to find.
  7. Beckster New Member
    Feb 22, 2009
    Message Count:
    11
    All sorted on the cards ... defo best way to go, Many thanks guys.
      • Advertising
Share This Page
