Adding hardware to Yamaha PSR S500 workstation
Hi Friends,:)
I have a Yamaha arranger workstation PSR S500. It sounds awesome. I would like to have more styles and more voices (sounds ) preferably synth sounds by using the same keyboard. Can any one suggest me any methods/ hardware where I can use my work station and get all the synth sounds and styles ( rhythms )
? I appreciate all your help... Venky.
India
Styles - Yes could load the user styles through the USB.
Sounds - You could edit the onboard sounds and save them as registrations. But this keyboard does not allow the samples(user sounds) to be loaded into the keyboard.
This feature is provided in the new Yamaha PSR S650. It should hit India by end of this year !!!!
Regards,
Jez
