battery noise
hi, i own a yamaha piaggero NP-V60.
i'm getting this loud electrical noise when the batteries die, here is a recording of the this sound with the keyboard volume set to half way (with some notes to give you a sense of relative volume):
http://www.markstockton.com/misc/batterynoise.mp3
i've tried using both 1.5V alkaline and 1.2V Ni-MH batteries and they both do it.
as you can imagine, if this happens during a performance people think my keyboard is broken and i have to explain that its just the batteries running out.
yamaha says this is normal.
has anyone else who owns a 'piaggero' keyboard experienced this problem?
The Y_man
Melbourne, Australia
It probably is normal.... similar to pulling the plug out of a TV.
How often do you run out? You might need to go to Lithium batteries?
The Y-man
yeah, the batteries do last for ~3 hours, so its not that much of a problem.
but this problem could be easily fixed with a relay, a transistor and a couple of resistors, basically 30p in components, and they should have already done this considering how long they've been making keyboards.
Using rechargeble 1.2 volt batteries in keyboards is a bad idea to begin with.
Just not enough power. You sure it is the batteries and not a bad potentiometer/volumeknob? Does it make loud 'cracklng' noises when you change volume? Only long distance guessing of course.
no but i would like to know if this is normal for all piaggero keyboards, or if it is just a defect with mine.
need someone with the same keyboard to see this thread :)
sorry I haven't used batteries yet.Don't plan on it either but if I do I will try to let you know what happens.Maybe I should get some to make sure I have no problem with it working
thanks for the reply, i found that the noise is less intense when using alkaline batteries over NiMH.
offtopic note: i'm using this "alkaline recharger" with regular Duracells and so far it's been working really well, they only charge 10 times but last longer, i may even stop using NiMH rechargables as i can pick up a pack of 4 Duracells for £1, something to consider if your buying batteries:
http://www.ebay.co.uk/itm/150653081988?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Ebbetsman
