Change Yamaha Tyros2 style to Casio rhythm
Germany
Hello
How can I Yamaha Tyros2 style (rhythm),
In Casio CTK 731 rhythm (Style) change?
the Tyros style has the following structure:
1. 3 Intro
2. 4 Main
3. 4 Fil In
4. 1 Brack
5. 3 Endings
6. Sync Start
7. Sync Stop
8. Stop / Start
and the style (rhythm) Postfix is .sty
Sory may English is "Google English" :(
Maybe someone can talk German? :)
Thanks for the help
Mirojan
You could try http://4server.info/download/4shared.com/zip/wR4r_L_j/casio_styles-software_stytockf.html
If you search, you can find some pretty good information on the internet about the structure of Yamaha style files, but I don't know what sort of information there is about the structure of Casio rhythm files.
If you want to convert an existing auto accompaniment file into a format that doesn't allow as many sections, you'll need to decide which sections you want to keep, or you could split the sections up to create multiple files in the target format.
Another issue is that the target format may not support the same types of MIDI commands that the original format does, so you may lose things during the conversion.
Also, when converting an auto accompaniment file for one keyboard into an auto accompaniment for another keyboard, you'll need to edit the values in the Bank Select and Program Change messages so that they properly select the desired instrument sounds (Yamaha calls them "voices," Casio calls them "tones") on the target keyboard.
Germany
Hello SeaGtGruff :)
Thank you for your quick response.
The stytoskf program convert from Yamaha .sty to Casio .skf
But the CTK-731 has .cpt or .ept rhythm format
My question is: How I can the .sty or .skf convert to .cpt /.ept
Mirojan.
Unfortunately, I don't have any information (yet, anyway) about how the various types of Casio rhythm files are structured. I found the STYTOCKF program by searching for "convert Yamaha style to Casio rhythm." If I had some CKF, CPT, and EPT files to examine, I might be able to determine something about how they're structured.
Accra
please your website is not working
Unfortunately, that post was from 10 years ago and the site I had linked to was not my site. If that site is no longer available, I don't know if the person who was developing the STYtoCKF program is still around. I found another link on the SynthZone site, but I don't think SynthZone is still active and I couldn't get that link to come up, either.
Texas USA
Here's a thread on the Casio forums about a style converter software developed by one of the frequent posters there. It appears to permit transformation of any MIDI (and by extension, older Yamaha .STY files) to Casio-format .AC7 rhythms. FWIW.
Bradders
