Extracting Sounds ?
Chester-le-street. County Durham . U.K.
Hi everyone,
Not sure if the post is in the correct place so please bear with me
I have a Roland E09 KEYBOARD/ARRANGER the question is
Is it possible to extract/download the actual instrument sounds
from the keyboard to my computer to use as samples. ??????????
Many thanks in advance Brian
Since the internal samples are propriety to the Korg file format, I doubt they are a direct download (as with a standard "wav" file format). There are sampling and conversion programs out there, but there is also a large learning curve invloved in do the sampling and editing. It is much easier to try and find a commercially available sample library which can suit you purpose. Don
