i intend to buy a new keyboard and i've found these two to be in my price range and can't really decide which one is best. i play in a metal band so i am going to use it on stage and also in the studio. any helpfull advice on what to go with?
WOW. thats a nice keyboard. I would sujest it yes because the motif is a great board.
HOWEVER. for metal, i will always feel KORG is the way to go, thats why all the metal guys use KORG. if you can buy a motif i assume you have the money for an M3 wich would be better for metal.
so i will sujest KORG for metal. Personally i feel yamaha only surpasses in its piano
might i just say again, as a metal player I use alot of strings and analog leads. You will find these better in KORG. Also the interface is much better then yamaha, if your live and you realize a program in your combi is bad, you can get rid of it in a click! with yamaha it seems to take a little longer
so yes go with KORG
Not quite... Yamaha has TONS of buttons instead of a touch screen interface.
I never had any trouble when it comes to managing my way around the ES.
There's a button for everything... you don't need to poke around the menus
since you can instantly get somewhere you want with a single press of a button.
But, yes... it is a totally different approach to editing stuff.
you are correct, however in my experience having button for everything can be bad, i personally find the touch screen much more interactive cause everything can be done in one setting. just my preference though, i mean people buy other boards for a reason.. i just cant understand why theyd go for a roland
Haha... My thought exactly... Actually i can think of one situation...
If I had the XS, M3 and tons of money I didn't need - I'd probably get the Fantom too![]()
