Help me find a Piano keyboard
I have a yamaha psr290 which I bought really cheap a few months go, since then I have become engrossed in playing it, I've never used the other functions and never have it off grand piano mode.
However, it does feel quite cheap and I would like to spend a decent amount on a new keyboard, particularly something geared towards a piano if that makes any sense..I dont want 2 million voices and all that jazz..just something that is a full size piano with a good sound and also occasionally use midi out with fruityloops.
It doesn't have to be new just out model so second hand is a possibility.
What can you recommend...?
Try to find a used Yamaha p120. Believe me... that's what you want :)
full 88 graded hammer action keys, great piano sounds, brilliant feel, and a couple of other sounds (i think 14 in total).
