I455 vs E09in
Indore
I'm planning to buy a keyboard.
And confused between these two : Roland E09in or Yamaha PSR i455
My budget is around 30000. Currently own a Casio CTK-810in.
Any suggestions ??
Sweden
Any suggestions ??
Hej Sanmesh Ajmera,
for me as a european it is difficult to give you a suggestion for instruments for indian music.
I would recommend the Roland E09IN because I think it has the better sound (polyphomy and speakers) and more choice of special indian sounds and styles too - but it is more expencive.
Here a short overwiew:
Yamaha PSR I455:
Polyphony: only 32
Preset Number of Voices 753 (incl. Indian 19 Voices)
Preset Number of Preset Styles 206 (incl.Indian 23 styles)
Registration Number of Buttons 4 ( x 8 banks )
Price: 23.900--
Roland E09IN:
Polyphony: only 64
676 tones including 56 Indian voices
135 styles including 63 Indian styles
133 Music Assistant with 69 programmed for Indian music
User Program: 100 program
Better loudspeakers
Price: 29.500,--
If you have the possibility you should go to a shop and test both instruments by yourself.
Indore
Thank you goldi for your suggestion.
Can you also tell me that do Roland E09in have registration buttons ?
If yes how many ?
Hej Sanmesh Ajmera,
Yamaha PSR I455:
Polyphony: only 32
Price: 23.900--
Roland E09IN:
Polyphony: only 64
Better loudspeakers
Price: 29.500,--
Hej Sanmesh Ajmera,
Yamaha PSR I455:
Polyphony: only 32
Price: 23.900--
Roland E09IN:
Polyphony: only 64
Better loudspeakers
Price: 29.500,--
Sweden
Hej Sanmesh Ajmera,
with Roland instruments the Registrations are called User Programs.
User Programs specify the type of tone and music style, together with other settings such as the keyboard part and various additional parameters. You can edit the settings and save them as a user program.
The E-09 provides 100 user programs (00–99). You can use these to store settings for most of the front panel operations and function menus.
Indore
Hej Sanmesh Ajmera,
Thank you.
Your suggestion is appreciated, Would soon purchase Roland E09in. :)
