Is it possible to route drum sounds and keyboard sounds on two different output channels (e.g keys on left and drums on right? this would be useful to record on external devices on different channels for separate editing.
Yes, Kross lets you pan sounds, so some sounds can come only out of the left jack and others only out of the right. However, on boards where you use panning to simulate separate mono outs, you may need to avoid using certain effects. For example, your "mono" left-channel-only sound, if put through a stereo reverb effect, can still lead to reverb from that sound appearing at the "wrong" output.
