What are you talking about?!
Do you know the difference between the two!?
When you load samples into your Fantom, and turn off the keyboard they are erased, and you need to re-load them each time you turn the keyboard on.
That's what happenes to every sampler today - Once you load samples into the XF ram, and turn the keyboard off they will STAY there permanently,
and there is no need for reloading them every time you turn the keyboard on. (except the initial 128mb that come out of the box. that's just regular RAM)
That's NOT the RAM you use in regular Flash drives, cause that RAM can't be used for sampling because it's way too slow.
There's ROM - internal sounds that come as a stock, and samples you can't erase.
Then there's RAM - the usual one get's erased once you turn the keyboard off - making you reload samples every time you turn the keyboard
USB Flash RAM - pen drives, sticks... call them whatever you want - It's a very slow RAM module that's used for compact storages and mobility.
And there's XF Flash RAM that's yamaha proprietary fast flash RAM that can handle very fast reading times enabling smooth sample streaming.
And since it's non-volatile ram , the samples loaded there DO NOT get erased by turning the keyboard off
And that's what makes the XF stand out - It's the first keyboard to have such a "feature"
