Power suply
I lost my transistors numbers for power supply they burned so l nolonger see the number for my E443 Yamaha keyboard can anyone help me with the numbers
I have a Yamaha keyboard E433 and it burns when l try to use a voltage of 30V it blast....so I lost my transistors numbers for power supply they burned so l nolonger see the number for my E443 Yamaha keyboard can anyone help me with the numbers
You said "transistors" a couple of times, so on the off chance that you mean the transistors burned up and you can't read the numbers on them to see what transistors to get as replacements, you can get the Service Manual from ElektroTanya:
30v
Were you trying to send your Keyboard into orbit?
You may well have damaged far more than the transistors on the circuit board.
If you can repair the keyboard yourself then that would be great but if you have to take it to a repair shop then the cost of the repair is likely to be far in excess of its worth.
As the 443 is now an old keyboard maybe it is time to look to buying a new one.
Staff online
New To V-Stage
