Preamp Question
Hi,
I currently have an Nord Electro 3HP, and am most likely purchasing two QSC K10 speakers. I will be playing a decent amount of rhodes, and I'm looking for a preamp that will warm and fatten my sound. I found that many of the preamps that seem to fit my needs are one channel. If I run my sound through a one channel preamp, am I not taking full advantage of my two speakers? Based on the answer to my first question, what are some preamps that you guys would recommend?
Thanks for your input,
Jordan
I can't recommend anything specific, but yes, one channel means mono. If you are processing a stereo signal you either need a stereo preamp or a pair of mono ones.
New To V-Stage
