PSR 9000 Floppy's ?
Does anyone have floppy discs that can be used in my ancient board? I am trying to get something with the same voice as my Yamaha organ (Marimba,Mandolin).
Netherlands
Most type of floppy's will work.
There is also a lot to find on psrtutorial.com.
I think the problem might be, HOW to get them on the disk......since most laptop's an PC's don't use them anymore....
Thanks for the reply. What I was looking for was perhaps someone had floppy's from back then that had some voice expansion so I could get some similar voices as from an organ.
Netherlands
There is a whole bunch out there especially for the PSR 9000/9000 Pro series.
Original from Yamaha MusicSoft.
I sold 9 packages of those on Markplaats in the Netherlands. ( Som sort of Ebay, or Craigslist)
You can track them down probably on Ebay.com
Thanks for the tip. Will have a look!
Bradders
