Set List
Hertfordshire UK
Hi, I need a refresher please. I have a song in set list which needs moving back one position, this will be to previous page. I activate arrow in drop box, move it back with the arrows at the bottom and it goes to previous page. The list ref. at the top shows asterisk, so I press write, this then shows Write Edit List Failed, but when I press O K it reboots keyboard.
Open your Setlist
Tap the down arrow on the top right and select ...... Enable set list edit
Then try again
If it fails again, we can delete the Song, don't panic it will only delete it from the Setlist.
Tap on the song to select it.
Select .... Delete Song and then tap on OK etc
Now try adding the song again but this time selecting where you want to add it too.
Hertfordshire UK
Hi Biggles, did all that even selected another song, all had same result. I then went to Save All, direct and reloaded and this put it back and now works as it should. Thanks again
Goad all is OK.
The SaveAll routine and selective restore shows its worth.
If I can give you another Tip, after you create new songs or registrations do another SaveAll before switching off the PA.
Btw, I name my SaveAll files as the Date it was created and they are all in a folder that I have named SAVEALLFILES and I then make a note in my paper PA log book of what I have done.
