Sustain pedal stopped working on Clavinova
Canada
Have any of you had a problem with Clavinova's sustain pedal no longer working???
Just wondering if it's a quick fix/faulty connection or or a common problem with the Clavinova...
A possibility
I use a PSR so I am not sure if I can help. If you have a utilities setting on the Clavinova make sure that the polarity is set to neg. or positive depending on your pedal. Try both ways to see which works.
