what attachments should i get 4 recording music?
Newmarket, Ontario, Canada
I'd suggest recording on your computer instead of on a keyboard. Alternately, find a keyboard that will save your songs on some kind of removable media or USB connection. For example, Korg's TR and M50 keyboards have an SD card slot that you can save to, and the Korg M3 lets you export via USB.
By the way, I'm guessing that the number of threads you posted are all to help you decide which one keyboard you want to buy. You'd be best off by going back to your original thread, listing everything you can think of (i.e. "I want a keyboard with 73 keys or more, high-quality sounds, ability to record, ability to sample and play back audio", etc.) and getting some responses that way rather than posting a number of isolated threads and trying to pull the results together.
