Can K2500XS sounds be "virtualized"?
Southern California
Howdy!
I'd like to export selected sounds from my venerable K2500SX and then be able to use them as a virtual instrument in my DAW.
Is that kind of thing possible?
Thanks ~
Not possible to export them as lossless data, but you could simply hook up your audio to your computer soundcard and record samples for each note and strike velocity. A bit tedious but doable for a few key sounds.
Bradders
