Casio wk7600
Yes. If you want it to affect only the organ sound and not any other sounds you may be splitting/layering with it (or switching back and forth between), pan your organ sound to one side and all your other sounds to the other side. Also, if you're using the Vent, disengage the board's own rotary effect on the organ sound.
Thank you
Are they worth the money their pricey ?
The rotary on the wk7600 is limited
Worth the money is subjective... but I don't think anyone disagrees that this is the best sounding rotary pedal. Which also means it's good enough that that there's a good chancle you'll still want to use it even if you upgrade your Casio to something else in the future.
Thank you
Bradders
