I bought a Casio wk-3800 and was not happy with it because it sounds like the casio wk-3000 with a few more added things. I have searched the internet for the wk-6500 and come up with limited results could someone tell me which is a better keyboard? thanks
I've got the WK3800 workstation, and yes it is the same engine with extras to the WK3000. But I improved things by adding some doorway draft tape( that has some spong rubber on it) to the top of the dampening under the keys on the keyboard. The other thing to do is get external powered speakers, the ones that it comes with are only for the bedroom practice. Before you get speakers try your keyboard on a powered PA( like at the church). You will hear a BIG difference and improved ambience from the board.
But in saying that the WK6500 is a better keyboard - I would prefer the WK7500
, if you are going that way. But you are still limited to the inbuilt 7 watt speakers.
Oh so much better than the WK3800, more features to keep you learning and having fun!
Best thing to do , is to try it yourself in the shop , maybe with a keyboard amp connected to it, say you looking at playing with others. Remember that an AMP is usually mono, so you will need to take that into consideration too.
Best of luck.
