I need help with software and manual..I think
Okay, so I found the Yamaha moXF6 used for a really good deal. However, it doesn't come with any software or manual. How do I go about getting both of those myself?
Thanks.
You can download the manuals, software, firmware, driver, and other content (such as additional waveform samples) from Yamaha's web site:
http://download.yamaha.com/search/p...ry_id2=16381&category_id3=&product_id=1816955
It's useful to have the documents in PDF form so you can search them for specific words or phrases you're interested in-- but if you'd like to have actual printed copies of them as well then you'll either have to print them yourself from the PDF files, or order them from Yamaha:
https://www.yamaha24x7.com/YamahaOMSMI/Landing.aspx
