i pad or Samsung
Planning to buy new tablet. Have Yamaha PSR 775 . Should I get Apple or Android to get me started ?. 80 yr old just playing for own enjoyment to avoid Coved cabin fever ;). Experienced player but not up on connecting computer, midi etc. like Cntry, Big band, easy listening, Celtic, etc. Appreciate suggestions.
Apple iPad all the way.
I would also suggest not to skimp on the inbuilt storage.
Connecting an iPad to your S775 is dependent upon which model you might buy. Some iPads have a Lightning connection and with these models a Camera Connection Kit is required c£35. New iPads like the Pro have USB and hence just a cable will be required to connect.
I Pad is the only way to go. I have both a Korg and Yamaha keyboards and the I Pad works well with both.
