Keyboard with faulty keys?
Hi,
My Roland Juno D has several keys that do not play, even after doing a factory reset. Does anyone have any experience of fixing this type of fault on their keyboard?
Help and guidance would be appreciated.
Thanks,
Paul.
Bath or Durham, England
That generally means that it's a hardware problem - some part of the physical keys are broken. If you can find a repairer for this keyboard, that would be your best bet, unless you feel up to opening it up and have a look. It might be something obvious like something has snapped off inside, or it could be a problem with the switch contacts.
josetabito
