LOW VOLUME
I HAVE A YAMAHA P35 THE VOLUME IS RATHER LOW ACROSS THE BOARD AND THE LAST 5 DEAD TOOK IT APART CLEANED ALL CONTACTS NO LUCK THEN I TOOK THE RUBBER STRIP FROM A SECTION THAT WORKED AND INSTALLED IT ON THE BAD SECTION NO LUCK THIS BOARD IS NEW TO ME AND SOMEONE SAID THEY HAVE LOW VOLUME BECAUSE THE SOUND COMES OUT THE BOTTOM THATS OK BUT WHY WOULD THE LAST SECTION BE DEAD MY GRAND DAUGHTER SAYS SHE CAN JUST HEAR THE NOTES NOT ME ANYONE OUT THERE HAVE AN IDEA JEL
Is it a new board? If it is new, why would you take it apart? I would return it for a refund. if it was given to you I'd give it back to whoever gave it to you.
MY APOLOGIES. YOU SHOULD USE THE BROWSER FEATURES AND EDITOR THAT COMPENSATES FOR VISUAL IMPAIRMENT.
BTW, IF YOUR GRANDDAUGHTER CAN HEAR THE NOTES THEN THERE IS PROBABLY A CONSIDERABLE PROBLEM WITH YOUR HEARING AS WELL.
NOT MAD I UNDERSTAND I JUST HOPE SOMEONE CAN HELP WITH WHY THE LAST 5 KEYS ARE DEAD I CLEANED THE BOARD AND SWITCHED THE RUBBER FROM THE WORKIG SECTION AND NO LUCK
New To V-Stage
