Midi Solutions "footswitch controller" problem
Ive been using this for years to work my Roland VK 8M Leslie effect on this Organ module (Midied out of many keyboards)
Now Im using it with my Nord Electro 5 but sometimes out of the Nord, the Footswitch controller doesnt recognize the Nord
& sometimes it does and works great any suggestions ????????????
The first thing that comes to mind is that maybe it's the MIDI channel that the Nord is using. Have you monitored the MIDI to see if you can notice a difference between when it works and when it doesn't?
Yes Nords midi set up is quite strait forward theyre both on the same midi channel
Im wondering if the box is getting old?
It probably is the bootup sequence, meaning connect everything and power on the footswitch controller before turning on the Nord. It works sometimes because it might get the power and make the connection after the nord has been fully booted, in other cases it might try and fail to make the connection because the nord isn't fully booted. They might be within milliseconds of each other other which would explain the 'sometimes' it connects. Experiment. And go both ways, nord first then connect the unit, then try connecting the unit (with power) and then fire up the nord.
I hope your right I’ll give it a shot
These controllers aren’t cheap
$150 CAD
I want to thank you for your suggestions it worked I first turn on Nord then I plug midi box in it works thanx DD
Bradders
